The switch authorizes ports by default, which means that the ports are always authorized and are not authenticated by the RADIUS server.
You can also make the ports controlled so that they are dependent on being authorized by the Radius Server when you globally enable EAP (auto).
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the authorization status of a port:
    eapol status {authorized|auto}
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface GigabitEthernet 1/1
Switch:1(config-if)#eapol status auto
The following table defines parameters for the eapol status command.
Variable
Value
authorized
Specifies that the port is always authorized. The default value is authorized.
auto
Specifies that port authorization depends on the results of the EAP authentication by the RADIUS server. The default value is authorized.
